Bobs Ten
RV-10
Wing Tips
1-10-2014
24-3.5>7
Install Left Wingtip
1300 - 1436
Remove silicone clamps on wingtip nut plates.
Using Permagrit c-sink, clean previously countersinked holes in wingtip of excess adhesive.
Install wingtip on wing using clecos and screws.
Verify tip alignment with aileron and flap.
Layout rivet lines for tip rib.
Drill holes in wingtip for tip rib using #40 drill.
Layout rivet center line on tip rib flanges.
Install tip rib in wingtip.
Using rivet centerline and pre drilled holes in wingtip, match drill tip rib using #40 drill, cleco as drilled.
With wingtip installed and tip rib clecoed in place, once again verify wingtip alignment with aileron and flap in reflex postion.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
