Bobs Ten
RV-10
Wing Tips
10-16-2013
24-2.1, 24-3.1>3
Install Wing Tip
1142 - 1506 1754 - 1906
Fabricate a 1/2" piece of 032 to use as a flange guide.
Layout flange trim line on right wing tip using guide.
Trim wing tip to within 1/16" of line, using small cutoff wheel.
Test fit tip on wing.
Layout and cut aft wing tip for aileron and hinge per plans, using small cutoff wheel.
Smooth and reduce wing tip flange using vixen file and 80 s/p.
Repeat until tip fits within 1/16" of tip flange and clear of aileron and hinge.
Install tip on wing. Match drill wing skin holes in tip using 340 drill, cleco every hole as drilled from front to back, alternating top and bottom.
Remove tip from wing.
Final drill wing skin holes using #28 drill, dimple for #6 screw. 48x.
Final drill holes in tip flange using #28 drill.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
