Bobs Ten
Date:  1-19-2014
Number of Hours:  0.60
Brief Description:  Install ER Tank Vent
1548 - 1624
Install left ER Tank.
Verify fit. The top aft tank mount flange was not flush with the rib when mount bolts were tightened. Instructions state that a spacer may need to be used.
Tank mount spacer was fabricated from 063 sheet.
Space was drilled for mount bolt and two flush rivets to retain it.
Machine c-sink spacer for flush rivets.
Cleco then rivet spacer to tip rib.
Install ER tank.
Locate vent line position and mark on tip rib.
Remove tank.
Drill tip rib for vent line bushing.
Debur hole and install snap bushing.
Install tank.
Verify fit and vent location.
