Bobs Ten
RV-10
ER Fuel Tanks
10-27-2013
Install Fuel Pump Doubler
1630 - 1818
Install tank in wing.
Locate tank vent location on tip rib.
Remove tank.
Drill 3/8" hole for snap bushing at vent location.
Install bushing.
Install test piece of 1/4" tubing and B nut on vent fitting. Install tank, verify proper fit of vent line in bushing.
Install AN822-4D fittings in fuel pump. Threads were sealed with Permatex #2 and clocked to position indicated in manual.
Drill pre marked pilot holes in doubler.
Clamp doubler to rib in proper location, match drill pilot holes in rib. Cleco pilot holes.
Mark fuel pump mounting flange outline on rib.
Layout rivet locations for doubler, drill each location with #40 drill, cleco as drilled.
Final drill all holes using #30 drill.
Drill pump mount holes for AN4 bolt.
Verify pump location and clearance.
Locate -4 nut plates on rib, match drill mounting holes using #40 drill.
Machine c-sink nut plate mounting holes for flush rivets.
Remove doubler.
Debur and smooth all holes and edges.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
