Bobs Ten
RV-10
Fuel Lines
6-8-2014
Install Fuel Supply Lines and Pre Filters
1530 - 1830
Determine best way to install pre filters and fuel lines.
Decided to use snap bushings and Vans support as well as flyefii.com supplied Adel clamp for filter.
Cleco stiffener mount top half to bottom half.
Enlarge supply hole for snap bushing using step drill.
Using 90 degree drill, match drill an additional hole in the top and bottom mounts for a screw, 4x.
Remove top half mount.
Debur all edges and holes.
Temporarily install inner and outer fuel lines, pre filters and top mounts.
Verify fit of all lines and clearances to controls.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
