Bobs Ten
RV-10
Fuel Lines
9-27-2013
Fabricate Fuel Valve Lines
1306 - 1548
Reinstall fuel valve to mounting plate using AN3 bolts, torque to 26 in/lb.
Install valve in tunnel.
Locate and mark correct length on outer line for stock bulkhead fitting.
Cut, debur, and smooth end of line.
Install flare nut and sleeve.
Double flare end of tube. Verify fit from valve to bulkhead fitting.
Repeat for other side.
Bent template for inner line. Will need to modify line slightly for clearance.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
