Bobs Ten
RV-10
Aileron Actuation
2-24-2014
OP38-4>5
Install Aileron Trim
1300 - 1454
Align and clamp aileron trim servo assembly to access plate.
Match drill servo mounting hole into access plate using #19 drill, cleco as drilled.
Remove clecos.
Final drill nut plate mounting holes using #40 drill.
Debur and dimple all holes for flush rivets and #8 screws.
Cleco nut plates to servo mount.
Rivet nut plates using p-squeezer.
Install servo mount on access plate using #8 screws.
Install aileron actuation centering jigs.
Locate center of servo throw using 12V power supply and two 90 degree reference squares.
Temporarily install trim servo assembly in wing.
Verify aileron in zero position with jigs.
Mark aileron pushrod at center of trim servo arm.
Remove servo from wing.
Remove aileron pushrod.
Locate and drill holes in pushrod per plans.
Debur holes.
Rivet spring attachment angles to pushrod using LP4-3 blind rivets with p-rivet puller.
Install pushrod in wing.
Install pushrod hardware, torque and safety with cotter pins.
Attach springs to angles.
Using a piece of safety wire, temporarily tension springs. Trim servo will be permantly installed after wiring and painting is complete.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
