Bobs Ten
RV-10
Aileron Actuation
2-2-2014
23-4>5
Install Aileron Torque Collar and Bellcrank
1300 - 1424
Locate aileron bellcrank and bushing.
Trim bushing to provide approximately 1/32" end play on bellcrank.
Debur and smooth ends of bushing.
Ream bushing with 1/4" ream for AN4 bolt.
Install bushing in bellcrank using synthetic super lube grease.
Install bellcrank and bushing assembly in wing using AN4-32 bolts and castellated nut with cotter pin. Torque to 60 in/ln.
Install torque collar per plans. To eliminate end play on the collar, a light washer was used on each end.
Torque threaded ends to 60 in/lb. Torques AN3 bolts to 23 in/lb.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
