Bobs Ten
RV-10
Aileron Actuation
11-18-2013
23-5.3>4, 23-6.1>5
Fabricate Aileron Torque Tubes
1318 - 1518
Insert torque tube collars into forward torque tube assemblies 1 1/2".
Match drill holes using #30 drill, cleco as drilled, 8x.
Final drill holes using #12 drill using drill press and vee block, through bolt as drilled.
Insert torque collar assembly into aft torque tube assemblies.
Fabricate a 5/16" spacer block.
Verify proper clocking and length of torque tube assemblies.
Match drill holes in aft torque tube assembly to torque collar, cleco as drilled.
Verify length and clocking of a LEFT assembly and a RIGHT assembly.
Final drill holes using #12 drill, drill press, and vee block, through bolt as drilled.
Disassemble both torque tubes.
Debur all holes.
Paint torque tube collars.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
