Bobs Ten
RV-10
Aileron Actuation
11-10-2013
24-3.2, 24-4.1>2
Aileron Torque Tube
1530 - 1700
Lubricate aileron bellcrank bushing using SuperLube.
Install right bellcrank in wing, torque pivot bolt to 60 in/lb.
Verify free movement of bellcrank.
Smooth edges of WD-1014 using bench sander.
Install threaded pushrod end into LONG leg of two torque tubes.
Match drill holes in pushrod ends using #30 drill, cleco each hole.
Remove clecos.
Debur and smooth holes.
Repaint areas of bare steel.
Install pushrod ends, cleco in place.
Rivet pushrod ends using MSP-42 rivets and p-rivet puller.
Label assembly as WD-1014 FWD.
Repeat for AFT torque tubes except use SHORT leg of torque tube.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
