Bobs Ten
RV-10
Aileron Actuation
11-3-2013
23-3.2>5, 23-4.1
Aileron Bellcrank and Pushrod
1654 - 1924
Layout bellcrank to aileron pushrod per plans.
Drill pilot holes, per plans using drill press, vee block, and #40 drill, 8x.
Debur holes.
Insert threaded rod ends into pushrod.
Match drill holes in threaded rod ends, cleco as drilled.
Debur holes.
Rivet threaded rod ends to pushrod per plans.
Install rod end bearings and jamb nuts. Two bearings are temporarily installed on the ailerons.
Fabricate two W-1031 spacers from AT6-058 x 5/16 aluminum.
Verify length of aileron bellcrank bushing. Reduced length using bench sander.
Debur and smooth all edges of bushing.
Debur bellcrank holes for bushing.
Verify AN4 bolt fits bushing.
Install Roll servo hardware on right aileron bellcrank.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
