Bobs Ten
RV-10
Brake Lines
9-6-2013
36-3.3>6
Finish Brake Lines
1130 - 1300
Finish brake lines.
Mark and cut correct end lengths for lines.
Polish ends of tubing, using 400 s/p.
Double flare ends of lines.
Actually, the next step was to put the flare nut and sleeve on the line...D'Oh!
Cut off first double flare, polish end of tube.
Install flare nut and sleeve THEN double flare end of tube.
Repeat 4x, putting the flare nut and sleeve on first.
Test fit brake lines.
Lines will be removed to paint firewall section.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
