Bobs Ten
RV-10
Baggage Door
5-25-2013
34-4.3>7
Rivet Baggage Door Frame, Skin
1200 - 1324 1412 - 1630
Dimple baggage door skin, closeout panel, and frames per plans.
Cleco hinge to frame.
Rivet hinge to frame using p-squeezer.
Cleco frames to skin.
Cleco Lock doubler to frames, skin.
Place door on flat table. Weight door to hold it flat while riveting.
Rivet skin to frames and frames to themselves per plans using 3x gun and p-squeezer.
After reading other builder's sites, I decided to add a stiffener to the middle of the door.
Fabricate stiffener from scrap J channel.
Locate and drill holes in stiffener flange.
Match drill holes in skin using #40 drill and stiffener as a guide.
Debur and smooth all edges using s/b wheel
Dimple skin and stiffener for flush rivets.
As I need to prime the stiffeners, I decided to prepare some other parts as well.
Separate ruddle pedals and doublers using bandsaw.
Debur and smooth all holes and edges of rudder pedal parts using bench sander and s/b wheels.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
