Bobs Ten
RV-10
Baggage Area
5-20-2013
33-8.6.7, 33-9.1>5
Baggage Bulkhead Corrugation
1300 - 1506
Secure lower baggage bulkhead corrugation with two screws.
Match drill holes along left side using #19 drill, cleco as drilled.
Match drill holes common to corrugation and bulkhed channel using #19 drill and centerline as reference, cleco as drilled.
Adjust right side cover to match corrugation.
Using SS ruler, straighten cover flange for drilling.
Match drill lower cover flange to baggage floor using #30 drill, cleco as drilled.
Match drill cover top flange to longeron using #30 drill, cleco as drilled.
Match drill right side corrugation holes to bulkhead using #19 drill, cleco as drilled.
Cleco upper corrugation to lower corrugation.
Match drill corrugations holes to bulkhead using #19 drill, cleco as drilled, from center to edges.
Remove corrugations and forward top skin.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
