Fabricate specified bushings fro 058 x 3/8 Aluminum.
The two longer bushings were faced to length using the Smithy lathe.
The two shorter ones were faced on one side with the lathe then sanded to final size using a bench sander and s/p block. The shorter bushings are only 3/16" long and could not be gripped in the lathe chuck reliably.
