Bobs Ten
Date:  3-4-2014
Number of Hours:  0.70
Manual Reference:  40-6.1>3
Brief Description:  Fabricate Flap Motor Bushings
1236 - 1324
Fabricate specified bushings fro 058 x 3/8 Aluminum.
The two longer bushings were faced to length using the Smithy lathe.
The two shorter ones were faced on one side with the lathe then sanded to final size using a bench sander and s/p block. The shorter bushings are only 3/16" long and could not be gripped in the lathe chuck reliably.
