Bobs Ten
RV-10
Flaps
3-1-2014
40-2.1>40-4.3
Fabricate Flap Torque Tube
1406 - 1512
Insert torque tube into flap crank, cleco two inbaord holes.
Match drill torque tube using #30 drill.
Final drill torque tube using #12 drill.
Install AN3 bolt and nut and tighten.
Remove clecos.
Final drill holes using #12 drill.
Install AN3 bolt and tighten.
Insert flap horn into torque tube.
Clamp torque tube assembly to bench.
Bolt bellcrank jig to flap horn per plans.
Set lateral position of horn at 24 7/16".
Final drill torque tube using #12 and 1/4" drills.
Install AN4 hardware and tighten.
Match and final drill remaining holes using #30, #12, and 1/4" drills.
Verify correct horn position by clamping crank to bench and checking horn angle with bellcrank jig.
Remove all hardware.
Debur all holes.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
