Bobs Ten
Date:  3-10-2013
Number of Hours:  2.30
Manual Reference:  21-1>10
Brief Description:  Complete QB Wing Ailerons
1312 - 1412 1506 - 1624
OK. After some time and consideration, I think I figured it out.
Apparently, Van's has made a change in how the ailerons are built.
My plans show revision date 02-23-12, which must be the new style ailerons. Looking at an older set of plans, dated 11-07-03, gave the solution to my problem.
The QB wing kit that I received obviously uses the old style ailerons. Van's must have known this because all of the hinge brackets were included in my kit, the PLANS, however, show an ENTIRELY DIFFERENT method for hinging the ailerons. Once I realized this, I proceeded to inspect and complete the QB Wing ailerons that came with my kit.
Locate all required parts.
Cleco and final drill hinge brackets and ailerons using #12 drill.
Aileron Section Complete.
Debur all holes.
Install brackets using hardware specified.
Torque all AN3 bolts to 24 in/lb and apply torque seal.
Fabricate aluminum spacers per plan.
Locate and temporarily nstall hinge hardware.
