Bobs Ten
Date:  1-28-2019
Number of Hours:  1.20
Brief Description:  Install EFII Harness
1800 - 1912
After a double check of the fWF harness wiring, I needed to support the tPS and intake air temp sensor wiring.
Fabricate an aluminum spacer for AN3 bolt.
Remove fuel rail Adel mid span clamp.
Install Adel clamp on IAT wires.
Install IAT clamp, spacer, and fuel rail clamp, secure with AN3 bolt.
