Bobs Ten
Date:  1-26-2019
Number of Hours:  2.70
Brief Description:  Install EFII Harness
1430 - 1712
Continue with the EFII harness.
The weather-pack removal tool arrived today. Shorten MAP sensor wiring and reinstall weather-pack connectors. All pins were crimped and soldered.
Bundle loom and install Adel clamp on clamp support.
Next, I needed to shorten the engine temp sensor wiring...again. There was excessive stress on the wires at the connector. I shortened the sensor wires and reinstalled metri-pack connectors. All receptacles were crimped and soldered.
Secure temp sensor connector using an Adel clamp.
Install previously fabricated loom supports, two on each side.
Begin wiring the odd side injectors. I began by separating the wires into three two wire bundles and secured them with a small piece of heat shrink. Next, a length of 1/4" insulating heat sleeve was installed over the 6 wire bundle.
