Bobs Ten
Date:  10-26-2018
Number of Hours:  1.50
Brief Description:  Install Fuel Pump Relay
1800 - 1930
Determine the location of the Fuel Pump Relay. I wanted this relay to be mounted in a convenient , centrally located area. I decided to fabricate a bracket that mounts to the forward part of the BM mount. This location keeps the wiring short, neat, and out of the way. The relay is accessible by removing the CF side panels, and is secured with one AN3 bolt threaded into a nut plate.
Standard techniques were used to fabricate and rivet the bracket.
Install fuel pump relay.
Install BM mount.
Verify fit.
