Brief Description: Install Main, Essential Bus Bars
1430 - 1700
Today I determined the final location for the main and essential bus bars. The power source for each bus is the respective battery, through the Bus Manager. The Bus Manager acts as a diode bridge so both of these busses should remain powered during any malfunction as long as the batteries can provide power.
Remove BM mount.
I opted to fabricate two mounts that attach to the BM mount. This location is convenient as both busses are readily accessible from the sides by removing the CF side panel. They are also centrally located which will keep the wiring relatively short. The essential circuit breakers will be located just aft of the BM on the available panel space just above the throttle quadrant.
Standard techniques were employed to fabricate the bus mounts which were then riveted to the BM mount.
