Bobs Ten
Date:  6-28-2020
Number of Hours:  8.00
Brief Description:  Install Empennage
Installed the empennage today per the plans.
All hardware was installed and torqued.
The wing bolts were then addressed. Unfortunately, it was apparent that several of the nuts were bottoming on the bolt threads instead of the spar surface. A call to vans was made and they confirmed that an additional washer could be used. Unfortunately, I had to order the AN960-916 washers from ACS, so the wing bolts will be finished when they arrive.
