Bobs Ten
Date:  1-5-2013
Number of Hours:  1.50
Manual Reference:  11-8, 11-9.1.2
Brief Description:  Rivet Empennage Attach Trim Servo Mount
1630 - 1800
Cleco trim bellcrank brackets, cable anchor brackets, servo spacer, and plate nuts to servo mount.
Rivet all parts per plans using p-squeezer.
NOTE: p-squeezer WILL NOT squeeze this length rivet in one try. Must open sets to squeeze only half way, then adjust sets and finish. Initially thought there was an issue with squeezer but searched VAF forums for the answer. Spent a hour trying to figure it out.
I am not the first...
Cleco trim servo link together.
Rivet link using p-squeezer.
