Bobs Ten
Date:  12-14-2012
Manual Reference:  11-5.5, 11-6.1.2
Brief Description:  Empennage Attach VS, Elevators
1336 - 1536
Final drill bottom holes in VS spar using #12 drill.
Machine countersink bottom holes for AN3 hardware.
Instal hardware.
Match drill remaing 2 holes to tailcone bulkhead using #30 drill. Final drill using #12 drill.
Install hardware.
Bolt VS to front spar attach bracket usinf AN4 hardware.
Install elevators to HS.
Verify elevator travel with no binding, stop to stop. Up stop required filing.
NOTE: In photo library pictures of digital level measurements.
Down travel = 26.1 degrees.
Up travel = 29.3 degrees.
Cut elevator pushrod tube to correct length, smooth and debur edges.
Check total elevator throw. Down was
