Brief Description: Rivet Elevator Rear Spar to Skins
1430 - 1530
Cleco elevator rear spar to right lower skin, left upper skin.
Rivet rear spar to right lower skin using p-squeezer in trim tab location. Remianing rivets were shot per plans.
Rivet rear spar to left upper skin. Rivets shot per plans. Started to rivet trim tab area with p-squeezer, then realized that is where the hinge goes later. Had to drill out several rivets.
