Trim forward SCAT tubing and attach to heat valve using SS hose clamp.
I wrapped the SCAT tubing with SVR tape at the location where it passed through the aluminum bracket to prevent chafing. I also wrapped it in the area of the fuel valve and spar carry through.
I decided to use a 2" duct elbow at the aft tee. This made the installation much neater and substantially easier to attach the SCAT tubing.
Once the dust was installed, I installed the aft tunnel cover to verify fit.
I began fitting the Aerosport symetrical panel. The first step is fabricating a support bracket that joins the aluminum back frame to the aircraft sidewalls. A 1" bracket is specified but would be impossible to use. I will contact Aerosport on Tuesday.
Trim and sand lower console and side panels to the scribe lines, rafius all corners, and smooth all edges.
