Bobs Ten
Date:  3-1-2012
Number of Hours:  1.10
Manual Reference:  7-11.3.4.5.6
Brief Description:  Rudder Counter Balance
1306 - 1612
Temporarily mounted counter weight.
Clecoed skins to counter balance ribs.
Started skirt bend by hand to locate crease.
Removed clecos and completed skirt bends, per plans, clamped with two hardwood blocks (one with a radiused edge) and a plastic mallet stiking a wooden block.
Temporarily mounted counter weight and clecoed skins in place.
Marked holes for mounting screws.
Drilled holes with #40, #30, then final drilled with #19. Drilled center hole for blind rivet to prevent pilowing.
Edge rolled outside skirt for lap joint.
Deburred all holes, countersink weight for #8 screw, dimpled skirts for #8 screw and CS4-4 blind rivet.
Reassembled counter balance and weight.
