Spent the better part of an hour trying to figure a way to put a uniform slight bend in the trailing edge of the rudder skin. Was hoping to use the brake but it is not long enough. Settled on using a flange roller with very light pressure. Taped both sides of skin with painters tape then lightly rolled edge. Satisfied with results.
Actual time needed to roll edges was only about 5 minutes after method was determined.
