Bobs Ten
Date:  2-20-2012
Number of Hours:  1.70
Manual Reference:  6-6.7.8.9
Brief Description:  Rivet Vertical Stab Bottom Rib, Skin, Spar Caps
1050 - 1232
Rivet vertical stab bottom inspar rib to spar webs with p-squeezer and rivet gun. Could not get squeezer into the corners so these were bucked manually.
Rivet vertical stab skin to rear spar with p-squeezer. Two rivets were manually bucked do to insufficient clearance for squeezer near hing bracket..
Rivet spar caps to spar below skin with p-squeezer.
Except for fiberglass tip and bottom, VERTICAL STAB COMPLETE.
VS Finished
VS Finished
