Install instrument subpanel and CF panel. Install lower console.
Fabricate shaft thrust bushing for pivot bolt. The bushing OD was smaller than the access hole in the side of the quadrant frame which allowed for unsatisfactory slop in the friction mechanism. The solution was a 3/16" wheel collar from the model aircraft inventory. It fit perfectly in the side of the quadrant frame. The bushing was shortened to accomodate the wheel collar.
Knob was installed and fit as well as operation was verified.
