Fit all pieces to determine where the mounting wedge would be best placed.
Locate and drill mounting holes in lower web of quadrant.
Top of mounting wedge was marcked with a center line and matchdrilled to the quadrant.
Nut plates were installed in side angles to facilitate tightening the mount in position from the outside. Standard techniques were used.
Install tunnel cover, lower console, and armrest. Locate quadrant assembly and mark the tunnel cover.
Remove all parts.
I decided to reloate two of the slots in the side angles to allow for nut plate installation on the inner side of the cover without interfering with the tunnel cover bend radius.
Drill tunnel cover and install nut plates using standard techniques.
Temporarily assemble quadrant, mount, and tunnel cover.
