Fit lower console and sides per Aerosport instructions. Using standard techniques, match drill 8 holes for nut plates. Install nut plates.
Install forward tunnel cover.
Trim and sand carbon panel such that it lays flat on the subpanel.
Drill centered pilot holes for two air vents and start switch.
Mark insert areas for 1/2" and 3/4" flange width using acrylic roller guides previously fabricated.
Install subpanel and carbon panel to verify fit. I decided to use the AFT rudder torque tube mounts, so the lower console sides will need to be trimmed to fit.
