A shim was necessary to provide a flush surface between the button and door surface. This shim was fabricated from 025 aluminum.
The next project is to fabricate a second button the sits flush with the door. As the dor is not flat, several iterations have been attempted using wedge spacers. I have another idea that I will attempt tomorrow that should yield better results.
