Bobs Ten
Date:  8-27-2017
Number of Hours:  2.30
Manual Reference:  47
Brief Description:  Install ShowPlanes Intake System
1500 - 1718
Install nut plates on bottom of tunnel for aft fairing mounting.
Match drill fuse skin to nut plates, debur, dimple, and rivet in place.
Begin work on intake.
Cut 2 7/8" hole in intake plenum end caps per instructions.
Fit to center plenum, verify fit.
Rough sand plenum exterior for application of epoxy/flox.
Install plenum caps and filters. The filters will postion the caps while the epoxy cures.
Verify uniform fit of caps.
Apply epoxy/flox/cabo mix.
