Bobs Ten
RV-10
Cowling
8-18-2017
Install Cowling
1524 - 1600 1930 - 2106
Remove Cowl.
Remove locking pins from skybolt receptacles.
Install aft lower cowl insert.
Locate and mark centerline on aft fairing.
Remove excess flange to rough measurement.
Locate and drill flange mounting holes, 7x.
Measure approximate relief for nose gear fairing.
Remove relief area.
Verify fit.
Scribe nose gear fairing on aft fairing.
Remove material and verify fit.
Repeat steps to fit aft fairing around nose gear leg fairing.
Once fit was achieved, match drill fuselage bottom to aft fairing, cleco as drilled.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
