Bobs Ten
RV-10
Cowling
8-6-2017
Install Cowling
1306 - 1730
Today I worked on the cowl side joints.
Remove clecos from skybolt brackets.
Debur all holes.
Trim brackets as required, debur and smooth edges.
Machine countersink all cowl holes for flush rivets.
Seal all c-sinks with CYA glue.
Final drill outside cowl inlet lip for 8-32 screw.
Position, drill, c-sink, and rivet nut plate to cowl inlet lip.
Cleco brakets in position.
Rivet all brackets using p-squeezer and appropriate length rivets.
Repeat all steps for other side.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
