Bobs Ten
RV-10
Cowling
8-1-2017
Install Cowling
1242 - 1430
Adjust side joint for no interference. Once the skybolt fasteners are in place, a final sand to obtain a uniform gap will be done.
Install several light sources inside cowl.
Install top cowl.
Matck drill top cowl in three places each side using cleco adapters and #30 drill.
Remove top cowl.
Install remaing rivets in firewall flange.
Clean firewall flange in preparation for firestop sealant. Unfortunately, the sealant that was remaining was hardened in the tube...
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
