Bobs Ten
RV-10
Fairings
12-10-2016
Install Nose Gear Fairing
1542 - 1712
Contniue to grind and smooth forward and aft fairings to facilitate a satisfactory fit using permagrit tools.
Locate and mark flange holes per plans by laying the measurements out on painters tape then applying the tape to the forward fairing.
Tape forward and aft fairings together and match drill flange holes using #40 drill, cleco as drilled.
Separate fairing, grind flange for fit.
Cleco fairings together, check fit.
Repeat to improve fit.
After several iterations, fit was satisfactory.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
