Bobs Ten
RV-10
Fairings
11-12-2016
48-7.2>4
Install Main Gear Wheel Pant
1748 - 2030
Final drill wheel pant mounting holes using #19 drill.
Machine c-sink mounting holes for #8 screw using permagrit c-sink.
Cleco pant halves together.
Final drill 3 holes per plans using #28 drill.
Remove clecos, debur holes.
Position and match drill nut plate mounting holes using #40 drill.
Debur holes and machine c-sink mounting holes for flush rivets using permagrit c-sink.
Cleco then rivet nut plates using p-squeezer.
Join halves using #6 screws.
Final drill remaining holes using #28 drill, cleco as drilled.
Debur holes and machine c-sink for flush rivets.
Machine c-sink holes using permagrit c-sink for #6 screws.
Machine c-sink axle extension mounting hole using permagrit c-sink.
Mix epoxy and apply to all c-sinks to seal f/g.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
