Open crate and inspect parts for damage, none found.
Remove material from wheel pant halves to facilitate fit around gear leg.
Install wheel pant and cleco together.
Level fuselage and mark fuselage centerline per plans.
Mark displaced centerline per plans.
Level wheel pant in pitch and roll per plans.
Drill hole for axle extension mount, final drill to 1/4".
Install wheel pant using clecos and bolt for axle extension.
Verify level wheel pant. Wheel pant does not align with centerline with bolt installed. I will need to remove additional material around gear leg that is causing interference.
