I needed to move the relay mounts as the seat base angle stiffener was interfering with them. The relay mounts were removed, shifted approximately 1/2" lower, and reinstalled.
The seat base cover was then fitted and attached. I then began installing the seat rails. After some research, I decided to accomplish the aft seat stop mod. This requires installing several nut plates in the seat base covers. These nut plates will allow the quick removal of the aft seat rail stop and will facilitate easy seat removal. Unfortunately, I need to source the hardware.
In preparation, I temporarily removed the aft seat rail stop and installed the rail with several screws. The mounting holes for the seat stop were then match drilled in the seat base cover.
Next, the rails were removed and the seat base cover was removed. I will install the appropriate nut plates to complete the mod.
