Bobs Ten
Date:  9-26-2016
Number of Hours:  3.40
Manual Reference:  48-05.1>5
Brief Description:  Prepare Cabin Top for Window Install, Install Fire
1400 - 1612 1730 - 1842
Finish preparing cabin top for window install.
Epoxy additional shims to window flange as required.
Install Howe bulkhead bushings for pitot and AOA lines.
Drill pilot holes using #30 drill then enlarge to 5/8" using unibit.
Debur holes.
Install push on to NPT fitting in Howe fitting and tighten. Fittings were sealed with paste.
Install Howe fitting to fuselage, clock fitting, and tighten bulkhead nut.
Repeat for AOA line fitting.
Install anti chafe covering on pitot and AOA lines for first 12".
Feed lines through fuselage bulkheads.
Install lines into push on fittings.
Install control cable spherical bushing (Cleavelandtools.coms in firewall. As I am using electronic fuel injection (flyefii.com), I only need two control cable, throttle and prop. No mixture cable is required.
Enlarge pilot hole to 1/2" using unibit.
Punch 1" hole in firewall using conduit punch.
Debur hole.
Locate and match drill bushing retainer to firewall using 1/8" drill, cleco as drilled.
Remove retainer, debur holes.
Install bushing backplate and match drill remaining 2 holes using a drill that just fit through the press nuts.
Remove back plate, final drill all holes using #30 drill.
Debur all holes.
Install backplate, retainers, and bushing.
Repeat for other hole.
