Bobs Ten
RV-10
Heat Valves
4-22-2020
Heat valve Controllers
1700 - 1900
The brakes were checked for leaks. None found.
Fluid was removed from the reservoir to obtain the correct level. The sintered vent was installed in the reservoir using Loctite 567.
I received the new actuators and control boards today.
The boards were temporarily wire and actuators tested.
Next, a smal proto board was modified to accept the two pots at the proper offset distance.
The pots were soldered to the proto board.
The 6 pin Deutsch connector was then wired and soldere to the proto board.
The proto board was temporarily wired and the actuator tested.
Tomorrow, I will install the new actuators and complete the wiring.
RV-10 Home
2834
Access Panels
Aileron
Aileron Actuation
396
Baggage Area
Baggage Door
Bottom Wing Skins
Brake Lines
Brakes
Cabin Top
100
165
Control System
Cowling
66
147
Doors
94
174
219
Elevator
Empennage Attach
Empennage Fairings
249
Engine Start Prep
ER Fuel Tanks
Fairings
54
108
Flaps
Flight Controls
Floor Panels
Front Fuselage
Fuel Lines
Fuel Tanks
Heat Valves
Horizontal Stab
49
54
Instrument Panel
Inventory
Lighting
Moving
Practice Tool Box
QB Fuselage
Rear Spar
Rudder Pedals & Brak
Rudder Pedals and Br
Seat Backs
Seats
Shipping
Tailcone
90
103
Tailcone Attachment
Top Wing Skins
Vertical Stab
Wheels
Windows
Wing
Wing Attach
Wing Ribs
Wing Spar
Wing Tips
