Bobs Ten
Date:  4-8-2018
Number of Hours:  1.30
Brief Description:  Install Heat Duct Bypass Cables
2006 - 2124
Fabricate bracket for cable Safe clamp using experience gained from the left side. The bracket was made from .125 1 1 1/2 x 1 1/2 6061 angle.
I found that attaching the Adel clamps on opposite sides of the engine mount tube and staggering the mounting holes in the angle bracket yielded the correct angle for the cable relative to the control arm on the valve.
Standard techniques were used to finish the bracket.
The cable and sheath were trimmed as necessary for fit.
The control was verified for operation and full range of motion.
This side went MUCH quicker!
