Bobs Ten
Date:  7-29-2016
Number of Hours:  1.50
Brief Description:  Install Heat Valve Servos
1848 - 2018
I am going to use servos to control the heat valves. This session was used to determine the best way to accomplish this. I had originally intended on using a low profile metal gear servo but after fabricating a trial version, I am leaning toward either a linear actuator or reverting to the original wire driven method. I will think about it tonight and decide...
