Unfortunately, the configuration tool is a windoze program. I had to go and get an adapter to plug the cable into my Macbook Pro, to connect the RJ45 ethernet cable. t then took some configuration changes in windoze 10 to finally get it to connect.
Once connected, I saved the current profile. Next I changed the label tags to represent each system more accurately. Because of the pin changes that were made a few of the c/b values needed to be changed. I will continue with that tomorrow.
