Bobs Ten
Date:  3-14-2020
Number of Hours:  1.90
Brief Description:  Install Instrument Panel
1800 - 1954
While organizing the tunnel console wiring, I realized that I needed to reroute the seat heater supply wiring to access the area under the seats from within the tunnel. The way it was routed, was above the tunnel cover.
Remove forward mid tunnel cover and wire pass through.
A new route was determined and the wires were rerouted. This required installing two additional snap bushings in the tunnel sidewalls.
The wires were then tie wrapped in their new locations.
Install forward mid tunnel cover and wire pass through.
Next, the console wiring will begin for the headset and microphone jacks.
