Today I completed the right wing root wiring connectors.
Installed 8 pin Deutsch connector for Nav/Strobe/Recog lighting on fuselage side wiring. Installed mating connector on wing side.
Installed Deutsch connector on right landing light fuselage side wiring. Installed mating connector on wing side wiring.
Installed Deutsch connector on aux fuel pump fuselage side wiring. This includes the white/orange wire. This wire is routed to a small molex connector in the center console. It was originally for the fuel pump LED but will not be used at this time. Installed mating connector on wing side wiring.
