Route remaining wing wiring through respective grommets.
Terminate end of GTP59 temp probe using Deutsch connector. This was required due to the short length of the factory cable. It was verified with Steinair that this is common practice.
Next, the elevator trim position sensor wiring was connected. Wiring from the tailcone was terminated using a Deutsch connector. The mating connector was installed on the wiring from the VPX.
